I got dnetc to work this way, keeping /programs0 always in rw mode so dnetc can store it's files there
If you want to reduce the risk, run the buffers out of a ramdrive. I did this with no problem back on my Mark 1, so there should be plenty of room for a RAM drive capable of holding a few thousand blocks. I ran a script that copied the buffers back to disk from time to time, remounting the drive each time. Only issue I had whas when it played with the mounts in the middle of an emplode session, but using the 32meg partition should resolve that as well.
