Well then, my problem must have been that I was over the max ampere raiting of the constant line coming out of the dashboard, obviously.
I have run a 12 gauge wire straight to the battery, with an automitive in-line fuse holder close to the battery holding a 3A fuse. So far, no problems. Unit powers up and plays normally. Extended play will be the final test.
Thanks for all your help, everyone.
