Q:When the display goes dim, check if there is a 'dimmer' option in the settings menu. The player maybe thinking it is in the car after you bring the unit out of standby.
A: there isn't a brigthness controll in SETTINGS menu.
Q:Have you checked all three fuses?
A: i have found only 1 fuse SMD near displayboard connector
Q:Does the remote work when the display is working at full brightness, or not at all?
A: yes before i opende my unit all was ok bright and remote and power off settings
Q:Install 1.03 firmware without hijack.
A: i have tried but all problen are present, before the unit was opened and workded good with b13+291.
i think that i need a new displayboard or main board or both..........damn
Rio Green 60Gb
