In reply to:
I had set the visuals to auto change at each track, but I wasnt using the visuals, only the info-track setting.
I normally run with visuals set to change on track change, and I've never had this problem when using info: track (or any other info mode), neither in 2.0b11 nor in 2.0b13. So it might not be the (only) cause for your problem.
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
