Loc: Cambridge UK
It's pretty obvious when the nipple breaks - it comes right away from the display and you're left with a hole there instead! If the nipple is in place and there's no sign of a crack or any missing glass then you're barking up the wrong street entirely, and Tony's fuse comments are almost certainly the real problem. If that's the case, after your earlier comments, I will slap you
