Pin number 5 of the sled port is connected to ground/chassis (Tested using a multimeter) and I hooked up the connector casing to the empeg ground, too.
So which ground could be missing? And, as far as I remember, only some empegs with serial numbers less than a value I don't remember had that problem. But I remember that value was low, at least lower than mine...
---------------------------- MK1: 00314 (4GB) MK2a: 030103104 (30GB) Installed in a BMW 323ti
