You must be getting some interference from part of the radio. try disconnecting the antenna and see if it goes away. Naturally you won't get any radio signal but it'll check.
The antenna usually has a signal core and a ground shield. You're probably getting the ground loop through there.
-- Murray I What part of 'no' don't you understand? Is it the 'N', or the 'Zero'?
