There are no flies on you, sir. Well done!
I must admit that when I read the article, I thought "Ah no, badly researched, not enough info" but if you actually spend the time to look at
all/ the drivers in the list one by one, you can see which basic drivers are required, and where they should go. I agree, after only a couple of days, there is no "massive improvement in reliability", but I am already seeing fewer "Mouse wanders", "Explorer Hangs", "Better Comms results", and above all, FASTER boot times which I very defininately will not argue with!
* Your results may vary!
