You know, this is bound to be a FAQ, but I can't find it.
Assuming it's just low voltage, the FAQ entry is here.
It could also be incorrect wiring, as you said. If, for instance, he used the COLOR of the wires as his guide instead of the labeling, he could easily have hooked up his headlight sense wire to the player's ignition sense wire, or worse.
