Note that a meter may well be showing you the RMS value, the full swing is almost 4v on a scope with a 0dB 1kHz sine ISTR.
The manual says 1 volt out and doesn't elaborate. I've actually never measured the outputs on the Empeg, just the other equipment. I will have to drag out the oscilloscope and compare the outputs of my various equipment to the RCAs on the Empeg.
Stu
