In reply to:
Can you post how you stripped your handle
I used a Dremel rotary tool and a sanding bit to get the original coating off of the handle.
To smooth the surface I sanded the handle with fine sanding paper first and to match the shiny finish of my NewFace used a rubbing compound in the last step.
