Maybe someone can help me with a little Hijack issue I'm experiencing: I have my Hijack menu set up to bring up a custom menu (Shuffle, KnobSeek, Sound, Next Source) when the knob is pressed. If I then select shuffle and press the knob again, sometimes it won't perform the task. I may have to repeat it three or four times before it will actually turn shuffle on or off.
Is this a problem other users are having? I couldn't find anything on the BBS. Please let me know if you can find anything wrong with my [hijack] and [ir_translate] configs(attached).
Thanks!
135172-config.ini (106 downloads)
MEast 40GB MK2a in '04 BMW 330CiC with BSW 300w Amp & 10" Custom Sub
