to remove a piston from a sulzer you just take the head off, undo the cross head, get the stuffing box out, take the wear ridge off then lift out the piston piece of piss.
that is a great post.
there has been enough interest shown in a easy-to-use app installer built into JEmplode that it will get implemented by someone, soon enough. when that gets done we'll put a step by step process into an FAQ that will have something like
part 1) procedure to install JEmplode (already written)
part 2) procedure to install hijack (already written)
part 3) procedure to download prepackaged apps from riocar.org
part 4) procedure to to click "install third-party application" and browse to the downloaded file
part 5) procedure to answer the really simple questions that JEmplode would then pose to you that would already have default choices.
it can't get too much simpler than that
John
