I'm trying to use Jemplode to edit my config.ini file and seem to run into an issue with actually saving the changes I've made.
I connected to my empeg (over ethernet), opened up the configi.ini and made my changes and hit ok. I then synchronized, and the config.ini still contains my changes. However, if I reconnect to the empeg, I get a notification box indicating that my changes haven't been made. Hitting OK and going back to the config.ini results in reverting back to whatever was there before I made any changes. Does this sound like an issue with Jemplode or a step I'm forgetting to do, or perhaps something I've done to cause the config.ini to not be editable?
