Umm. Maybe there's a process running that's using /drive0.. Quite possibly emphatic.
Run this:
ps -ef
And if you see anything running on the music partition (emphatic, or whatever else) kill it by noting the process ID (the number in the first column) and typing:
kill 123
assuming the process ID is 123. Then try running rom and ro again to mount read-only. My guess is you botched the chmod command and accidentally ran emphatic.
