Hi Patrick, I've tried emailling you and it keeps bouncing.
I suspect your ISP's IP address blocker also blocks emails from the same IP address ranges that it blocks http requests from.
So, in order to send you my tuner order stuff, I've PM'ed you on this BBS, can you check your email and respond - you may have to PM me as now doubt your ISP will block outbound emails to my IP address and in any case, I would not be able to reply to you for the above same reasons.
