Yes. If you can't find a copy of that AskTOH episode, I feel I need to point out that they ran normal PVC pipe to a sealed tub-like thing a little bigger than a WetVac. I assume that they are sold expressly for this purpose. The sewage pump was set in the bottom of it with the electrical cord running through a seal in the lid. The pump cuts on when the sump fills to a certain point. I forget exactly how the piping was run from the sump to the drain.
