Ahh, here we are....
empeg-car bootstrap v1.02 20001106 ([email protected])
If there is anyone present who wants to upgrade the flash, let themspeak now,
or forever hold their peace...it seems not. Let fly the Penguins ofLinux!
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux..................................... done, bootingthe kerne
l.
Linux version 2.2.14-rmk5-np17-empeg50 ([email protected])(gcc versi
on 2.95.3 20010315 (release)) #5 Sat Dec 22 10:18:24 GMT 2001
NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel ComputerCorp.
empeg-car player (hardware revision 9, serial number 40104298)
Command line: mem=16m
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4kinit)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:111999 )
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
Could not find CS4231A (version=80)
empeg state support initialised 0089/88c1 (save to d0004600).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHM2100AT, ATA DISK drive
hda: FUJITSU MHM2100AT, 9590MB w/2048kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC00:02:d7:28:10:c
a
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem)readonly.
change_root: old root has d_count player.cpp : 550:empeg-car2.00-beta7
(internal) 2001/12/22.
Note the bit in bold, it's the same chip that does the aux in as well as the input for the tuner.
I'd do a serial log and see if the same error appears.
