A screw on each side forms the hinge which holds the handle to the player. Use needle nose pliars to unhook the springs from the player and the old handle will come away. Two more screws on each side hold the steel bracket to the handle. Remove these but be careful as they are tiny. It's important to use a screwdriver with the right size head (small!) otherwise you'll chew up the screws.
Now reattach the steel brackets to each side of the new handle. The screws cut their own thread into the aluminium handle so take care to drive them in straight. Fix the handle back on the player using the two larger screws, again taking care to drive them straight.
Finally the fiddly bit - reattach the springs to the player using needle nose pliars - this can take some practice!
Rob
