Hi,
I've got a Sun Blade 100 in work and we're trying to set it up to connect to the internet through our proxy server. The Sun has a SunPCI PC card installed and we can connect fine with that, but using Netscape from Solaris (solaris 8 by the way) just doesn't want to know.
As far as we can see, the only configuration needed is the IP address and port of the proxy server. The first time we attempt to access a web page it asks for a password and username - now this is where we could be failing - we're trying to use our standard Windows/network logon username and password (including domain). After a short time, it fails with the message 'Proxy authentication failed'.
As far as we can see, we're doing everything OK; but I thought I might ask the greater knowledge that is this BBS for any suggestions/hints! Should this be working? Should it accept the logon or is there a different way of doing it?
Pretty Frustrated.
