Can you post your entire (well, edit out personal data) config.ini? I am wondering if there is a some kind of conflict somewhere. Otherwise, those options should work...
So it may be something with my kernel - I have recompiled it (but i think i didn't change anything important).
I have shortened config.ini just to test it - I get the same errors. The file below is exactly as used by me - there is no personal data but it works anyways. Note that entries from the begining and end of file seem to be OK. It is just [hijack] section causing errors. I could suspect there is no hijack kernel, but it is there: it certainly works, and errors are pritned out after "Hijack: intercepting config.ini".
[synchronise]
seq_num=27
[hijack]
fake_tuner=1
ir_debug=1
trace_tuner=1
suppress_notify=0
kftpd_verbose=1
khttpd_verbose=1
[output]
notify=1
timecodes=1
