Okay. Now that my Empeg's in my Mini, I found out that yeah, it's time I set up the ir_translate section. Most importantly, I want to be able to scroll BACK thru visulizations. So, I wanted to.. uh.. hijack the long press of the "Visual" button on the remote.
I opened up my config.ini, and added:
[ir_translate]
20DF15.L=PrevVisual
In theory, at least, as far as I can tell, this should work. It's the ONLY thing in the section, and that's what I understood the "Previous Visualk" button code to be. Note that I have used, in place of the "20DF15.L", "Visual.L" and "Visual+.L", with the same effect.)
On bootup, I get the Hijack (v338) error message, "ir_translate config error".
Also, I noticed that something (probably Emplode?) modified my section:
[serial]
car_rate=115200
to:
; ??? [serial]
car_rate=115200
So, first off, am I doing something dumb? (Okay, I mean, in regards to this..) And what is changing my 'serial' header?
Thanks!
Mike 'Fox' Morrey 128BPM@124MPH. Love it! 2002 BRG Mini Cooper
