I have a 800 watt Rockford Fosgate amp that gets very hot after about 30 minutes of play. It is installed in my 99 civic which is a very small trunk. The amp is mounted at about a 75 degree angle on the fold down seats inside the trunk. This amp is overheating (southern cal heat) very regularly and I would like to install some 12 volt case fans (80 mm or so) for cooling. I just want to know any suggestions or reccomendations that anyone has on this type of install. Also considerations with regard to power and some type of switch/control system.
