In what situation is that? With or without the remote connected? Both?
The amps are in really tight spots, so I could only test it with the remote wire out of the memphis amp, i.e. only connected to the empeg-remote.
Workaround: hmmm... I'd try running both the BAT+ and remote terminal off a relay controlled by the real remote wire (gives positive control of the remote terminal as well) if you can find a relay that can handle the current.
Sounds like a possibility. I'll probably try that.
You might get thumps - haven't ever wired an amp that way... and different amps act differently when it comes to thumping anyway.
Shouldn't be a major deal, since that amp only powers the small, mid-high frequency speakers anyway. Bigger deal will be to get to all the wires and get good connectivity, the way everything is installed now LOL
Any warranty left on the amp?
Bought it used off Ebay...
Thanks for your help!
