Hi there,
Instead of cancelling the wizard, humour it by going through the motions of installing a driver (which will obviously fail, because you don't have / need one) but at least then the system has the hardware in its list, albeit "not working" which should prevent the wizard............... MAYBE!
Good luck in your quest to slay the wizard............ Sim
