I had always assumed (based on nothing but pure ignorance) that audio compression was like text compression -- the less variety, the more compression.
Audio compression can be that way, depending on the implementation of the compression algorithm. MP3 at a constant bit rate isn't like that, however.
And with audio, what counts as "variety" isn't the same as you'd find in a text file. With audio, it tends to be high frequency information that's hardest to compress.
___________
