I added support for the Palm brand devices' 5-way navigators. This would be the Tungsten and the Zire series. Select takes you to the playlist screen, and the back button functions the same as the back button on the screen. If you press the select button while in the playlist screen, it will beam the playlist to the Empeg.
This release also fixes a bug when activating the menu after activating the command bar would cause the app to crash. The About screen is also now compatible with PalmOS 3.0 devices.
