There is another thread where others are discussing the possibility that a wiring fault in the PCA tuner module kit is causing the player to go into standby. Do you have a tuner attached?
Also, double and triple check the wiring, especially the main ignition-switched wire, and look for things like loose wires on the docking connector and blown fuses.
