Okay, here is a warning to one and all. Don't copy over your config.ini. I was using a couple different ini files (for different Ethernet addresses) and I ended up copying over the Sync counter. If I hadn't done this, Emplode would have recognized that my sync count was out of wack, and prevented me from overwriting a couple dozen of my fids. The problem isn't as bad as I originally thought, but it is still annoying. If you have to edit your config.ini, use sed to substitute values. I'm sure there's other important stuff in config.ini that you shouldn't copy over, mine is probably just one example of a bad side effect of this. Just a word of caution.
-Tony
MkII 080000554
