Where'd you put the sub?
The Sub enclosure is one of the Q-Logic Q-Customs. It holds one 12" sub and is specifically designed to fit on the tranny hump behind the center console. I was sceptical at first, especially because of the ABS construction, but to my delight the sub chamber is actually 1/4in. MDF. Nice tight bass from it.
Also, where'd you get the 1.5 din to single din panel that's around the empeg?
The din plate is actually just a Scosche kit I purchased at Walmart. I bought the Metra kit first but ended up returning it bacause of how deep the empeg sat inside the panel (just didn't look right and was a real pain to remove the unit from the sled .)
CLS
