Tony, a small enhancement for version 1.6 for you. Currently the tooltip for the icon in the task bar is 'empegface 1.5'. Any chance of including the hostname/ipaddress.
Ah, I take it that means you've got two separate copies working for two separate empegs? That's cool, I was trying to remember what other birds I was killing with the stone of the Winsock calls.
It sounds like changing the tooltip might be do-able, so that's on my to-do list now. Thanks for the suggestion.
Also, I tried doing a screen capture using paintshop pro of the pair next to each other. However, psp doesn't capture them.
It must be a malfuction in that version of PaintShop, because I just got a perfectly good screen shot, including transparency and everything. The resulting screen shot is attached to this post.
Of course, I didn't use PaintShop's "screen capture" feature to do it. Didn't you know that screen captures are built into the Windows OS? The PrintScreen key captures the whole screen to the clipboard (then you select EDIT-PASTE in PaintShop), and Alt+PrintScreen captures the currently selected window. Both methods worked for me just now when I tried them.
