all I needed to do what push the IDE connector into the MB a bit. Seems kinda odd that this could have worked itself loose so easily, but there ya go.
If it was only the connector loose, consider yourself lucky.
However, check to make sure that it's not the IDE header solder joint problem. If it is, pushing on the connector might seem to temporarily solve the problem but it will come back later.
