--alt-preset standard should be all you need if you have "LAME MP3 Encoder" selected for "Parameter passing scheme". You'll have to put %s --alt-preset standard %d if you have "User Defined Encoder" from the pull down list. Both do the same thing.
The alt presets are VBR, so you don't need 128 on the command line.
Edited by SE_Sport_Driver (25/01/2004 21:22)
Brad B.
