There's some more info here.
Yes, indeed.
I have the correct software version (3.0 something or other) in my TiVo, I have downloaded the script file, and have copied the instructions for installing it:
It's simple to install:
rename to padhack.tcl
Upload the script to your tivo (I used /var/hack)
chmod 777 padhack.tcl
./padhack.tcl
reboot
and just to prove how dumb I really am... I don't understand them.
How do I go about uploading the script to my TiVo?
Where he references /var/hack, I am guessing he means create a directory called /var/hack (if it doesn't already exist) and somehow put the padhack.tcl script there.
chmod 777 probably means set the permissions to make padhack.tcl executable?
If that's the case, ./padhack.tcl would only run if /var/hack were my current active working directory, right? So I would need a cd /var/hack somewhere along the way. (Hey -- it's been more than 10 years since I have done *anything* in a Unix environment, so don't think too badly of me...)
If I try this (assuming I figure out how to load the script into my TiVo) is there a chance I could mess up my TiVo and make it not work any longer? If I did that, is there a way to fix it?
I'm sure you would never suspect this except for my telling you, but I am not very experienced when it comes to TiVo hacking.
