Hey,
I appreciate all the work you did MLord. Please don't take any of the following as insults as they are all able to be worked through.
I received the Rio Board yesterday as well as the LAN91C96 Chips. Unfortunately it is the wrong chip (it is rectangular, not square).
I had the person that is going to solder it look at the board and she brought up a couple of problems.
1.) The pad on the LVX4245 D5 pin is gone. That leaves nothing to solder to. She is going to create a jumper from there to the D5 line that you created. A more permanent solution than what you created.
2.) The pad on the SMSC LAN91C96 D5 pin is also gone. She wants to create a jumper but needs to know where to jumper to. We looked at the board and couldn't figure out where it went. Do you know where to connect the other end of the jumper to?
