looks like the jumper pin was intermitent. thanks
empeg-car bootstrap v1.02 20001106 ([email protected])M:6144b MAC 00:02:d7:26:09:3
hda: hda1 < hda5 > hda2 hda3 hda4
hdstress.cpp 1
RAMDISK: Loading 320 blocks [1 disk] into ram disk... done.p
e000 v1.0429): Poll
Copying kernel...
Calling linux kernel...time reached, running e
hdstress.cpp 189 ( 29): Poll result=0 on fd=5
l.
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315rive
hdstress.cpp 189 (
(release)) #11 Tue Apr 1 18:49:59 BST 2003
Processor: Intel StrongARM-1100 revision 11pinning down.
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)stress.cpp 189 ( 29): Poll result=0 on fd=5
hda:
Speed checking /dev/hda
Buffer cache hash table entries: 16384 (order 4, 64k)pp 189 ( 29): Poll result=0 on fd=5filesystem fou
Read/write
POSIX conformance testing by UNIFIX[1 disk] into ram disk.
Linux NET4.0 for Linux 2.2
Based upon Swansea Universit29)
Seek test complete: 37.83
ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11 1999 )lt=0 on fd=5
Stressing /dev/hd
Starting kswapd v 1.5
Stressing /dev/hda: S
ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UARTess.cpp 189 ( 29): Poll result=0 on fd=5
ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UARTtress.cpp 189 ( 29): Poll result=0 on fd
empeg display initialised.
hdstress.cpp 189 (
empeg dsp audio initialised5
empeg dsp mixer initialisedress.cpp 189 ( 29): Pol
empeg dsp initialised
empeg audio-in initialised, CS4231A revision a03
hdstress.cpp 189 (
Read/write of 8
empeg state support initialised 0089/88c1 (save to d0004100).
Stressing /dev/hda: Spinning down.
empeg RDS driver initialisedcpp 189 ( 29): Poll resu
Stressing /dev/hda: Spinning up.
RAM disk driver initialized: 16 RAM
ide0 at 0x000-0x007,0x038 on irq 6024 (log=0)
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
2375
hda: IC=Nzwqmvss04-
hdb: IC25N040ATCS04-0, 38154MB w/1768kB Cache, CHS=4864/255/63
empeg-flash driver initializedDISK drive
smc chip id/revision 0x3349per group
hda: IC
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Vcb: 0x4086d000
riocar Mk2A 030102357 - 60 Gb
