The FAQ entry is here. I'm guessing that you've done one of two things:
- You may have connected your power antenna's activation lead to something other than the antenna lead on the tuner module. For instance, you may have connected it to the amp remote wire instead.
- You may have the RDS Traffic Announce feature turned on in the software.
And the recommended resistor, by the way, is 1k, not 10k, I don't know if that makes a difference.
