I'm looking for some tips on troubleshooting a non-working displayserver setup.
I'm using the packages as supplied in the other posting and built the new arf using tarMerge.exe. I've stopped and started both the receiver and the app.
When the receiver comes up it goes looking for the server then displays that it found the server and then doesn't do anything else.
I'm assuming that it's died loading the new kernel (or exec'ing it), the power button doesn't work and I let it sit for a bit.
If I put the old .arf back in all is fine.
I also removed my playlists and mp3's so that it shouldn't be a filelist issue (even though there are only 600mp3 at this point).
the server is a w2k server and works fine without the patch..
any suggestions?
thanks
bob
