Java(TM) Plug-in: Version 1.4.2_01
Using JRE version 1.4.2_01 Java HotSpot(TM) Client VM
User home directory = C:\WINDOWSProxy Configuration: No proxy----------------------------------------------------
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
p: reload proxy configuration
q: hide console
r: reload policy configuration
s: dump system properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
java.lang.UnsatisfiedLinkError: C:\Program Files\Java\j2re1.4.2_01\bin\net.dll: One of the library files needed to run this application cannot be found at java.lang.ClassLoader$NativeLibrary.load(Native Method) at java.lang.ClassLoader.loadLibrary0(Unknown Source) at java.lang.ClassLoader.loadLibrary(Unknown Source) at java.lang.Runtime.loadLibrary0(Unknown Source) at java.lang.System.loadLibrary(Unknown Source) at sun.security.action.LoadLibraryAction.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.net.InetAddress.<clinit>(Unknown Source) at java.net.SocketPermission.init(Unknown Source) at java.net.SocketPermission.<init>(Unknown Source) at java.net.HttpURLConnection.getPermission(Unknown Source) at sun.applet.AppletPanel.getAccessControlContext(Unknown Source) at sun.applet.AppletPanel.getClassLoader(Unknown Source) at sun.applet.AppletPanel.createAppletThread(Unknown Source) at sun.applet.AppletPanel.init(Unknown Source) at sun.plugin.AppletViewer.appletInit(Unknown Source) at sun.plugin.viewer.LifeCycleManager.initAppletPanel(Unknown Source) at sun.plugin.viewer.IExplorerPluginObject$Initer.run(Unknown Source)
looks like some problems here - any idea what?
Tone
