It sounds like you are using a separate amplifier connected to Rio's line out?
If so, you could have a ground loop. See if the amp and the Rio are plugged into the same electrical circuit -- this may solve it. A good way to ensure this would be to plug a power strip into the wall, then plug both units (amp, Rio) into the power strip.
