Aren't you seeing an SQL error in the JReceiver logs when you get the "bus-problem getting album menu recs" error?
Previously people have seen the following in the JREc logs:
Root cause: java.sql.SQLException: General error: Got error 'empty (sub)expression' from regexp
It's the query that caused this that I'm curious to see.
Paul (the tRio guy)
