#225751 - 04/07/2004 18:40
Re: jEmplode 56
[Re: mschrag]
Quote: If Peter or other happens to know what might be causing this, I'll fix it up.
The underlying issue is that we misused strtol(3), not realising that -- as well as defaulting to decimal and allowing "0x" to specify hex -- a leading zero specifies octal, so "08" and "09" are illegal input and come out as zero. What I can't immediately remember is where these numbers with leading zeroes came from -- perhaps if people have track number strings with leading zeroes they got put straight into the *1 files and interpreted as octal. If so the fix is to always convert track numbers to numeric rather than string type, and write them out in decimal, thus ensuring no leading zero.
