Hi,
could a bad header produce this error?
I think so. I'm not sure why Mark explicity said it wouldn't be soldering problems. That would include bad IDE cables too.
Mark,
Can you explain why you think it's not a dodgy cabling or soldering. Is it simply because they aren't actually drive errors? If the cable was only a little bit dodgy couldn't date get corrupted enough to cause program crashes?
