but the empeg doesn't do that every time you switch it on.
That leads me to the question: When does the empeg do that? Is it after X number of re-synchs? Is it after X number of playing minutes? Is it after X number of disk sectors are filled? Is it after a random time seeded by the sum of the digits on the license plate of Hugo's Miata?
I notice that the older (read: more filled) my empeg gets, the longer it takes to complete this process. So is it only checking those sectors with files in them?
Will there ever be an option to postpone the disk check, perhaps just a yes/no dialog box before the check begins? And how long does it take Rod (aka: mardibloke) to disk check his 64 GB empeg?
