I thought that might be mentioned. However, the unit is impossible to remove without removing the entire centre console, as it is with all Jags. Even if you were to destroy most of the surrounding fascia in order to release the unit, you still can't pull the device out of the mounting hole without putting the gearbox in Drive, which you can't do without the ignition on. I know potential thieves might not be aware of these issues, but on the other hand they might know that Jaguar radios are normally pretty hard to remove.
Still not 100% happy with it, mind you.
Gavin
