#231251 - 23/08/2004 16:21
Re: New to empeg, need some help.
[Re: meth222]
Quote: Ok I got it to work with the USB. Now I have gone into File, Configure Player, to try to change the IP for Player but it still doesn't work with the ethernet.
Please be specific and explain what you mean when you say "it still doesn't work".
With the USB cable connected, after exiting emplode and restarting it, are the new player IP address settings correct, or did they seem to revert back to their old settings? If they reverted back to their old settings, we're talking disk problems, such as a the synch not working and the config.ini file isn't getting written properly.
If the new player IP address settings are correct (the settings "took"), but the player still isn't being found on ethernet, then we're back to checking the cable type. Did you ever go and read this and this? If not, please do so now, read them carefully, because your problems is likely one of the ones listed there.
What are the IP address and netmask of the player and the PC now, after you made the change?
Can you ping the player from a command prompt? ping 192.168.0.2
Is there another device on your network that already has the address .2?
meth222
21/08/2004 23:48
TigerJimmy
22/08/2004 00:08
meth222
22/08/2004 18:30
mtempsch
22/08/2004 18:53
meth222
22/08/2004 19:02
mtempsch
22/08/2004 20:06
meth222
22/08/2004 21:33
meth222
22/08/2004 23:24
SE_Sport_Driver
22/08/2004 23:28
meth222
23/08/2004 15:36
pgrzelak
23/08/2004 15:40
SE_Sport_Driver
22/08/2004 22:14
SE_Sport_Driver
23/08/2004 18:01
meth222
23/08/2004 20:08
LTJBukem
24/08/2004 05:39
SE_Sport_Driver
22/08/2004 03:22
meth222
22/08/2004 18:18
schofiel
22/08/2004 19:41
SE_Sport_Driver
22/08/2004 22:13
schofiel
22/08/2004 07:49
SE_Sport_Driver
22/08/2004 11:37
meth222
22/08/2004 18:19
meth222
22/08/2004 18:31
meth222
23/08/2004 17:45
schofiel
23/08/2004 17:51
meth222
23/08/2004 20:09
