do you remember what you did that caused the fuse to pop?
in most cases, the fuel circuit wont run if there is no ignition trigger. this doesn't mean 'spark', but but the trigger that tells the coil(s) _when_ to spark.
take a little time to check all other electrical bits (inside lights, cig lighter, horn, power windows......)
if you find anything else unusual it can really help pin point the offending circuit.
