In the boot log, it pauses at "Freeing unused kernel memory: 4k init"
Here is the boot log, in its entirety:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
(release)) #12 Tue Apr 1 18:51:41 BST 2003
empeg-car player (hardware revision 9, serial number 30102965)
Command line: mem=16m
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)
Linux NET4.0 for Linux 2.2
Based upon Swansea Universit
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005400).
empeg RDS driver initialised
RAM disk driver initialized: 16 RAM
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:9
5
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k inithda: irq timeout: status=0xd0 { Busy }
ide0: reset: success
end_request: I/O error, dev 03:04 (hda), sector 4
EXT2-fs: Couldn't read superblock on 2nd try.
hda: status timeout: status=0xd0Busy hda: drive not ready for command
! tags.cpp : 61:Failed to open tags (0xc0041002).
Vcb: 0x4086d000
Thank you guys for the help, this is the most helpful forum I have ever been a member of.
Many thanks
-Joe
