#233938 - 20/09/2004 03:13
Re: Run Empeg on Batteries?
[Re: genixia]
Loc: Providence, RI
Quote: The other heavier and bulkier options are either a 12V motorcycle battery (lead acid - ugh) or 9 D cells. IIRC, a Duracell D cell is approximately 8000mAh, so that would give you nearly 3 times the duration of the RC packs, although that would come at the expensive of weight. bulk and the fact that you couldn't recharge them.
Sadly, if you're talking about any serious amount of ampere hours, you can't beat lead acid on price. Of course, for this, it's probably overkill.
If they still made em I'd have suggested an Evertroll NiZn battery, which would have given you a pile of play time...
