Damn, downloading MP3's? How 90's. I'm running the new MInd2Disc software. All you need is the IP address of your favorite artist's brain and you can stream a copy of anything they've recorded, or will soon record, direct to your hard drive. Keep in mind you have to run it in multi-process mode if you want each band member's instruments. Version 2 will be out soon and it will allow for a full orchestral download in one sitting (well, up to 255 individuals anyway).
What's better than having the song even before it's been mastered? If you're really lucky, you catch the band on a night after a bender and you get a really limited special remix. There's a plugin available that's compatible with producer's brains too, but it's still a bit buggy.
